C3 Antenna Cable to Antenna Connection - NCRS Discussion Boards
  • Robert S.
    • June 30, 2001
    • 230
    On my 74' I want to verify the integrity of the antenna cable to antenna connection at the rear fender location. The AIM is unclear on how the part are mated. Question: From above can I remove the antenna and take off the base bezel nut and pull the antenna cable and base up through the hole from above? Or do I remove the antenna, take off the base bezel nut, remove the left side muffler and pull the antenna cable and base down from below?
  • Steven B.
    • June 30, 1982
    • 3991
    Re: C3 Antenna Cable to Antenna Connection
    Robert, when I changed out my original antenna temporarily on my '77 I went through the top. It saves alot of work.
    Steve
    • Jim T.
      • March 1, 1993
      • 5351
      On my 68 and 70 the part of the antenna assembly that the bezel connects to is not going to come out of the antenna hole. I don't have to remove a muffler either. I have even changed out the antenna on a C4 and did not remove a muffler.
