muncie shifter mount on a 66 - NCRS Discussion Boards
  • Bill S.
    • January 31, 2007
    • 396
    i see 2 ways to mount the shifter on my 66 a trans mount and a frame mount. what dictates the mounting method? the shifter or trans or niether? i have a nov 22nd build. it currently has a fact looking hurst.
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: muncie shifter mount on a 66
    Originally posted by Bill Snyder (46851)
    i see 2 ways to mount the shifter on my 66 a trans mount and a frame mount. what dictates the mounting method? the shifter or trans or niether? i have a nov 22nd build. .....
    Bill --- It was a running change at the St.Louis assembly plant. If no one comes up with the date or VIN, I can dig into my Tech Service Bulletins tomorrow. I believe a definite VIN # is quoted for the mounting method change.
    • Michael H.
      • January 29, 2008
      • 7477
      Bill, as wayne mentioned, there was a TSB that showed the date the change from transmission mounted to frame mounted shifter occured. That date is 21 March 66.
      • Bill S.
        • January 31, 2007
        • 396
        are the tail shafts and shifter bodies the same? is it just a matter of what mount you use?
        • Mike M.
          • May 31, 1974
          • 8400
          tailshafts and shifters same. you'll just need the bracket that mates the shifter to the frame if you want the 2nd design mount method.mike
          • Bill S.
            • January 31, 2007
            • 396
            i have both mounts. i prefer the early design as i have an early car.
            • William C.
              • May 31, 1975
              • 6037
              Tradeoff was more precise shifting with the trans mounted unit, less vibration with the crossmember mounted unit. The crossmemer in the frame will not have the holes added for the mount if the car was equipped with the trans mounted shifter, at least until very close to the changeover.
              Bill Clupper #618
