Just finishing my rebuild on my L-36. On my last TF judging I got dinged for improper washers on my rad core support washers thru rad to shroud.
I bought my 66 from the org owner with 39k org miles, so many items were correct. However, I have these two center THICK washers that were in the middle of the core support and they look really old. They are 1.25 inch in diameter and almost 1/4 inch thick. The other 4 washer on either side that go thru the top Rad brackets are also 1.25 inch in diameter but the standard washer thickness (thin). My AIM calls for a P washer and bolt, my Paragon and CC Central Catalogue just call them washer and bolt. My Noland Adams Tech C2 Book looks to have the large washers but it is hard to tell in the blk/white pictures.
Can someone with some authority tell me the proper items to have here, bolt washer, what thickness and what diameter washer. I believe I have the right head and length bolt. Much appreciated.......
