65 Steering Gear Box Rebuilders - NCRS Discussion Boards
  • Dick G.
    • May 31, 1988
    • 681
    Who do you recommend to do a Steering Gear Box rebuild for my 65? Quick turnaround and reasonable. Thanks
    DG
    13180
  • Dick G.
    • May 31, 1988
    • 681
    Re: 65 Steering Gear Box Rebuilders
    I removed my steering gear box. I clamped it in my bench vice. The arm is still attached. When I steer all the way to one side, the arm will slowly fall down on it's own. When I steer the other way, the arm does not fall down. Something is awry. I do not own an Inch/lb. torque wrench. May have to ship out. DG
    • Henry S.
      • April 30, 2005
      • 816
      DG
      13180
      Dick, Go to the members list at top of the page and contact Gary Ramadei. He rebuilt my 67 steering box and it couldn't be better. Very reasonable and he knows what he's doing. There is another thread going on now titled "1965 steering box finish". Gary replied to that thread so if you click on his name you'll be able to e-mail him. Good luck, Shooter
      • Dick G.
        • May 31, 1988
        • 681
        Thanks Henry.
        DG
        • Dennis S.
          • April 1, 2004
          • 228
          Try calling Corvette Steering Service Inc
          2215 Mullinax Drive
          Anderson, SC 29625
          864-287-9990
          • Craig O.
            • July 31, 1983
            • 207
            Bairs corvette for sure , excellent work and quick. you wont be disappointed www.bairs.com
            • Peter C.
              Infrequent User
              • June 30, 2006
              • 7
              I agree - Bair's does great work!
              • Jim S.
                • August 31, 2001
                • 730
                My vote goes to Gary Ramadei. I have followed his postings and replies on several other forums over the last several years. He knows his stuff.
                BTW, how did Saginaw Steering Gear fill the gear with grease?
                From the Saginaw assembly drawing:
                "Lubricate gear with 11 oz. lubricant per SSG spec 5695023 thru side cover bolt indicated." (Indicated is side cover bolt on centerline of gear).
                Jim
