Frigidaire AC Compressor ID - NCRS Discussion Boards
  • Erv M.
    • February 21, 2007
    • 445
    I have a core with the following numbers:
    A-3
    6555302
    L-18
    What do I have?
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: Frigidaire AC Compressor ID
    A-3
    6555302
    L-18
    What do I have?
    Erv -- you seem to be describing the rear head of the compressor. Here's a pic of another with a cast date of I-15-4 (Sept 15th 1964). How close does the format, font & placement of the lettering on yours correspond to this, and does it have the pressure relief valve screwed into the head [this one has a slot with 440# stamped].
    Just guessing, but these "302" rear heads were on compressors used in the '60s, before the superheat switch electrical connection was added. Others may be able to give more precise dates. Do you have the whole compressor ? Is there a number after the L-18 ? Could be a date (Dec 18th_?). Is there a label on the compressor barrel ?
