Care and cleaning a new soft-top (60) - NCRS Discussion Boards
  • Greg L.
    • March 1, 2006
    • 2291
    I've never owned a soft-top car in my life so what's the best way to clean and take care of the top?
    Is it better to store the top up or down?
  • Mark P.
    • May 13, 2008
    • 951
    Re: Care and cleaning a new soft-top (60)
    I was told to store it up or it will shrink and you won't be able to get it to close again. My top was changed 20 years ago in my 1960 and looks new but since it was stored in the down position I can't close it. I would always store it with a a rolled towel tucked into the clear window and would never leave it down more than a few weeks.
    • Joe M.
      • April 30, 1990
      • 1343
      You can use a mild dishwashing soap with a soft bristled brush, then rinse it off. If you are lucky, you can put a tight top out in the sun for half an hour and it will loosen up enough to latch down. I installed my top a little loose (not intentionally) to take into account the shrinking with age.
      • Gary B.
        • September 30, 1987
        • 305
        To stretch my top I opened the rear hatch, put the top up with the rear hanging, hung some weights from the latch points, and let sit in the heat.
        It stretched back to normal.
        • Mark P.
          • May 13, 2008
          • 951
          Gary - I'll give that a try. Should it be in the sun ?
          Mark
          • Gary B.
            • 305
            Mark
            The sun will work. I put mine on the lift near the top of the garage where it was the warmest.
            • Steven B.
              • June 30, 1982
              • 4020
              Greg, all good advice given. I installed the top on my '57 in the summer of 1965. 'Bought it from Chevy Parts. I always wash it when I wash the body with a mild car wash and brush it in circular motions. The window has yellowed some (I polish it with conv. top window polish) and the thread is weak in some areas but very good for 40+ years. If it is too tight I let it set in the sun until it is pliable and I can latch it but storing the top up eliminates the problem.
              Steve
              • Greg L.
                • March 1, 2006
                • 2291
                Thanks guys. The top is new so I should be able to keep it looking that way now. It has a few dirt marks on it and some cat prints from some where that I'd like to remove. Is it best to let the top dry on it's own or to towel dry it?
                • Joe M.
                  • April 30, 1990
                  • 1343
                  Drying - your choice, but I would use a chamois to avoid lint. You will still need to let it air dry at the end because you can't get it 100% dry with towel or chamois. Good Luck.
                  • Joe M.
                    • April 30, 1990
                    • 1343
                    Greg, when you do store the soft top (short term or long term), be sure to put soft towels or other cloths at the corners of the soft top before you close the hatch; the weatherstrip corners will rub on the underside of the top hatch if you don't.
