63-67 Alternator Stator Color Judging - NCRS Discussion Boards
  • Gerard F.
    • June 30, 2004
    • 3806
    Re: 63-67 Alternator Stator Color Judging
    Chris,
    Here's my original 67 (7F16) alternator (37A):
    Note the ring between the halves is basically rust, and kinda looks like caramel.
    However, if you take it apart to swap stators and rotors with a replacement, you'll find that the ring was actually painted black. Here's a shot of two stators (original on the left):
    The color might be different on sizes other than the base engine 37A alternator. It should be noted that the capacity of these alternators is determined by windings in the stator. The 61 amp stator (on the right above ) which I put in my original, has heavier wiring and a slightly different windings.
    Here's my finished 37A (aka 61A) alternator:
    I guess I now have the wrong color on the ring.
    Jerry Fuccillo
    • Chris E.
      • November 3, 2006
      • 1331
      Thanks Jerry.
      Chris Enstrom
      2011 Z06, red/red
      • William L.
        • December 1, 1988
        • 944
        Just curious, how did the alternator stators with black painted center ribs judge at Bloomington?
        Did anyone loose points for either black or caramel?
        Michael; This is the original alternator on my 67, received a 5 point deduct for plating/finish. Nothing said about the stator. Bloomington June 26 2009. Bill
        Bill Lacy
        1998 Indy Pacecar
        • Dick W.
          • 10483
          FYI Torrington was purchased by Timken several years ago. All bearings have Timken on them now.
          Dick Whittington
          • Gerard F.
            • June 30, 2004
            • 3806
            Bill,
            Geez, your alternator looks more like the original finish than the reskinned restored ones. 5 point deduct for what. I guess Bloominton is a different type of judging.
            Jerry Fuccillo
            • Wayne M.
              • March 1, 1980
              • 6414
              Originally posted by Stephen Lavigne (7553)
              Gene,
              How about posting a photo of a correct Torrington bearing so we all know what to look for....
              Steve
              Steve -- pics of an NOS Torrington were shown in this thread:
              https://www.forums.ncrs.org/showthre...ngton&uid=5271
                • 11652
                Originally posted by Gerard Fuccillo (42179)
                Bill,
                Everything at BG is in 5 point intervals. So, the smallest amount per item to lose is 5, then 10, 15 or 20.
                • Stephen L.
                  • May 31, 1984
                  • 3158
                  Wayne,
                  Thanks for the thread location and photos
                  • Michael H.
                    • January 29, 2008
                    • 7477
                    #24
                    Do I see a hint of some remaining black on the stator on the far left side?
                    • Gene M.
                      • April 1, 1985
                      • 4232
                      #25
                      Steve, Chris, check out the post that Wayne sites an old posting that has a very good photo of a Torrington bearing
