Was there any design difference between the 40709 and 40956 fuel pumps? I had previously read that the difference was just a part number change. I have one 40709 and a 40956 and notice in comparing the two that the angle of the nipple outlet points in a different direction between the two.
The 40709 points more toward the motor and slightly back, while the 40956 points more away from the motor and in a slightly back angle.
The angle of the 40956 seems more logical in that it is more toward the metal line coming from the tank.
I see no evidence that the 40709 has been modified. Is this the angle that should be expected from an original 40709? Or has this likely been modified for some reason??
The 40956 is on left and 40709 is on right in photo
