This is a 59 vette. I was in the process of lubing the stearing gear box using a hand grease pump. I was filling the box through the top plug when I noticed that the rubber end piece was no longer on the end of the hose but is now somewhere down in the box. Is there some way I can take the box apart without removing the entire column from the car? This box hasn't been moved in 50 years and I'm afraid once I start, I'm going to run into problems I can't handle. If I need to remove the enire column, what special tools will I need to remove and reinstall? What about just driving the car with the rubber piece in the box, it is a soft rubber nipple, what affect will it have? Help. and thanks.
Steve
Steve
, time to sell the Corvette cheap
