1969 SB Water Pump Question - NCRS Discussion Boards
  • Steve M.
    • January 1, 2006
    • 258
    I have a 1969 350/350 with a 3782608 water pump. From some previous discussion post there should be a 'S' on the rear of the casting for a correct pump. I did not find an 'S' or a 'T' on the casting. The impeller does have 3923250 GM SM H9 cast into the back. I would appreciate any information that anyone could provide.
    Thanks in advance,
    Steve
    • 43258
    Re: 1969 SB Water Pump Question
    Thanks in advance,
    Steve
    Steve----
    Not all Saginaw-cast '608' waterpumps have the "S". However, as long as there are no reinforcing "ribs" on the driver side of the pump, it's a Saginaw-cast pump.
    • Steve M.
      • January 1, 2006
      • 258
      Joe,
      Thanks for the information.
      Steve
        The 'T' emboss is typically found on the front side of the pump's case in/around the viscinity where the casting number 'lives'....
