1985 Blower Motor Switch Inop. - NCRS Discussion Boards
  • Paul S.
    • June 30, 1982
    • 359
    ONLY HAVE "HIGH" SPEED WHEN I TURN ON BLOWER SWITCH. ANY IDEAS WHERE TO CHECK?
  • Mike T.
    • October 23, 2006
    • 79
    Re: 1985 Blower Motor Switch Inop.
    sounds like the blower resistor has opened up. it should be in the air stream held in by some screws with a 4 prong plug. if you lift the hood it is on top of the heater ac housing
    • Jim T.
      • March 1, 1993
      • 5351
      Paul from what I have lightly read in the 85 GM service manual Mike T. has given you some good information.
      High blower speed power comes from a relay directly to the fan motor.
      The other speeds are controlled by the resistors.
      • Paul S.
        • June 30, 1982
        • 359
        I'm Working On It Tonight, Thanks For The Help!!
