Front suspension progress - NCRS Discussion Boards
  • Chris E.
    • November 3, 2006
    • 1326
    Well, master gurus, what say you all? (I know, I haven't detailed the chassis yet with all the right paint marks, but OTHER than that)
    67 327/350 4 speed red convertible.
    Chris Enstrom
    2011 Z06, red/red
  • Tim S.
    • May 31, 1990
    • 704
    Re: Front suspension progress
    Looks great Chris. Where are you looking to debut it?
    • Chris E.
      • November 3, 2006
      • 1326
      Either the North Central or Heartland Chapter meets this fall.
      Its first regional will most likely be the Heartland regional in Iowa next May. Then look for me in either Gettysburg or North Carolina. I'll be the one with the red 67. (heh)
      Chris Enstrom
      2011 Z06, red/red
        • 11643
        I "think" that the lower portion (half?) of a 67 spindle is supposed to be orange. You may want to check into that, as it's easiest to dip it.
        Patrick
        • Jim V.
          • November 1, 1991
          • 587
          Nice job Chris! Based on your quest for knowledge I know your project will be appreciated by many. Chassis should be the least of your worries.
          Since every judge likes to find something, are those lower ball joint rivets?...painted?.... I believe they SB natural.
          I still owe you some pics of hood blackout paint line on my orig paint 65!
          Good luck
          Jim
          • Chris E.
            • November 3, 2006
            • 1326
            Patrick
            Yup, I know. Haven't gotten there yet.
            Chris Enstrom
            2011 Z06, red/red
            • Chris E.
              • November 3, 2006
              • 1326
              Good luck
              Jim
              Thanks Jim. The ball joints are original style GM replacements with rivets. I know they should be natural. I tried to approximate that finish as best I could.
              Chris Enstrom
              2011 Z06, red/red
              • Gene M.
                • April 1, 1985
                • 4232
                Patrick, I think Chris will be fine. The spindle castings generally have orange marking on the upper half. Not all are so completely covered, some are more striped. So he should be able to add that anytime. I ran into an original 66 BB that also had a blue dab in the middle under all the grease. What it means , I don't know.
                • Chris E.
                  • November 3, 2006
                  • 1326
                  Just curious, on the painting orange of the spindle, was that done after the car was assembled? In other words, would the spindle rod bolts be orange too?
                  Chris Enstrom
                  2011 Z06, red/red
                  • Stephen L.
                    • May 31, 1984
                    • 3156
                    My spindle pieces had orange on top on one side and the bottom of the other. They looked like the paint was done before assy. Nothing at all fancy.... just get some orange markings on them.
                    • Chris E.
                      • November 3, 2006
                      • 1326
                      Thanks Stephen. Hey, I had a nice chat with your nephew the other day. Saw his Dodge Carryall at the last show here in the Twin Cities. He gave me your number, hopefully it's Ok if I call sometime and we talk about 67s.
                      Chris Enstrom
                      2011 Z06, red/red
                      • Stephen L.
                        • May 31, 1984
                        • 3156
                        Chris,
                        No problem on the call....
                        Were you at "BACK TO THE 50's"? Great car show!!!!
                        • Chris E.
                          • November 3, 2006
                          • 1326
                          Yup, sure was. Wasn't sure if you knew it by that name or not. Anyway, I saw a LOT of cars there that I really liked. In particular was a 64 327/365 4 speed AIR coupe, originally silver over silver/black.......there can NOT be many of those running around.....
                          Chris Enstrom
                          2011 Z06, red/red
                            Chris -
                            The orange was applied at Chevrolet-Warren, where the spindles were manufactured, before the hub/rotor/caliper and steering arm were attached; it was then shipped as a complete assembly to St. Louis.
                            • Chris E.
                              • November 3, 2006
                              • 1326
                              Thanks John!
                              Chris Enstrom
                              2011 Z06, red/red
