On this 60 Vette the engine builder forgot to install the 1/8th inch spacer that is placed on the end of the crankshaft before pressing the harmonic balancer on, so the pulley was sitting too close to the block for the generator belt to align properly. Here's what I did to fix the problem without removing the balancer; a chore for sure with the engine, radiator, fan shroud, etc. already installed. The balancer has to be heated / expanded to press back onto the end of the crank shaft; a chore that would have been
I used three sets of 5/16th's washers that equaled 1/8th of an inch thick for the three bolt holes and attached them to the back of the pulley to take up that space; I had to buy three longer bolts to attach the pulley as the original bolts would not be long enough for proper torque. I then used a larger spacer (had to use a die grinder to grind a hole large enough) to fit around the lip that sits inside the balancer to take up that space to ensure the entire surface of the pulley would be flat when I torqued the three pulley bolts to the harmonic balancer. It fit like a champ; probably would not pass a Bloomington inspection, but this car will not be in that category anyways. Proof in the pudding will be when I fire the beast up and see if the pulley is true while spinning; I'm surmizing all will be okay because the pulley looked very flat and true.
I'll post pics tomorrow.
once upon a time GM sold a pulley reinforcement that fit inside the crank pulley that may have worked in your case but i do not remember the thickness
