Radiator 315116 61J - NCRS Discussion Boards
Radiator 315116 61J
  • Berndt U.
    • December 31, 1998
    • 72
    Radiator 315116 61J
    Hello
    I just found a new Radiator # 3151116 61J .
    Has anyone Information about this Radiator and use application.
    Berndt
    • January 31, 1988
    • 43196
    Re: Radiator 315116 61J
    Originally posted by Berndt Unnasch (31579)
    Hello
    Berndt
    Berndt----
    GM #3151116 is applicable to 1960 and early 1961 Corvettes. It is a top tank style radiator.
    • Berndt U.
      • December 31, 1998
      • 72
      Thanks Joe
      but thes still use the Expansion Tank on this cars ?
      • John S.
        • July 29, 2009
        • 640
        Berndt----
        joe, i have been researching this radiator and according to nolan this radiator was suppose to replace the 1960 type aluminum radiator #3147516. the date code of 61j would certainly suggest this and i think this would have been used on a early to mid 62, code 582 car.
        • Cecil L.
          • May 31, 1980
          • 449
          TSB's and further discussion here:
          • Ray C.
            • June 30, 2001
            • 1132
            This information is from the Thomas Dewitts web site:
            Ray
            Ray Carney
            1961 Sateen Silver 270-HP
            1961 Fawn Beige 315-HP
            • Mike E.
              • February 28, 1975
              • 5135
              John--
              That would NOT have been used on a mid-62 car. The radiator support was different for the top tanks vs. the aluminum rads with separate expansion tanks.
              The 61J radiator that is reference would be an over the counter GM replacement radiator made September 1961 as a replacement for 60-61 top tank that had failed.
              • John S.
                • July 29, 2009
                • 640
                Originally posted by Mike Ernst (211)
                John--
                thanks mike. that explains the late date code. would all radiators after 1700 in 1961 then be part #3150916?
                  • January 31, 1988
                  • 43196
                  John------
                  Please note in my original response that I said the GM #3151116 radiator is applicable to 1960-E61 Corvettes. That does not mean it was the radiator originally used on all of these. The GM #3147516 was a predecessor radiator to the 3151116. The latter radiator replaced the former for SERVICE in December, 1960. However, even as early as April, 1960 GM was cataloging the 3151116 for 1960 Corvettes with mechanical lifters.
                  I agree with Mike and do not think that the 3151116 was ever used on a 1962 Corvette. As Mike also mentions, the 61J dated 3151116 which was mentioned in the original post in this thread is a SERVICE piece. In fact, we know that it has to be a SERVICE piece since it is described as "new". No PRODUCTION-utilized piece could be described as "new" at this point.
                  As a matter of fact, the GM #3151116 was available in SERVICE until July, 1972, so I would expect that its manufacture continued at least until the late 60's, if not later.
