69 SB Radiator Drain Plug - NCRS Discussion Boards
  • Steve M.
    • January 1, 2006
    • 258
    I have a 69 350/350 with the brass copper radiator. It has the correct number for the radiator and what appears to be the original lower hose. The radiator and supports look to have never been removed. The radiator has a plug in the drain. I can not tell if it is brass or steel. My question is, does this radiator have a traditional drain or plug?
    Thanks in advance for any comments or advise.
    Steve
    • 15640
    Re: 69 SB Radiator Drain Plug
    Your radiator should have originally had a copper/brass hex head plug threaded into a copper/brass right angle fitting threaded into the bottom of the passenger side header tank, alongside the lower radiator hose.
    Sorry for the run-on sentence.
