Replacement C3 trailing arms - NCRS Discussion Boards
  • Michael L.
    • December 15, 2006
    • 1424
    I'm looking at getting some replacement trailing arms for my 69. With the shape mine are in, I'm not convinced they can be rebuilt at a reasonable cost. I need the whole setup with rotors, e-brake, everything. Does anybody have any recs on who sells the best complete trailing arms? This will be for a judged car.
    Mike
  • Gerard F.
    • June 30, 2004
    • 3806
    Re: Replacement C3 trailing arms
    Mike,
    I got mine for my 67 from Paragon. They were the whole setup with new riveted on rotors, p-brake, ready to just bolt on. Nearly 100 % correct,
    I got the later larger lugs for the strut's on the bearing housing. You can order them with or without the holes for a rear stabilizer
    Pretty pricey, but I got them within a week. They actually came from Ikerd's. I think Bair's also has the same deal.
    Pretty happy with the one's I got.
    Jerry Fuccillo
    • Dick W.
      • 10483
      Bair's. Has a very good replacement. www.bairs.com
      Dick Whittington
      • Michael L.
        • December 15, 2006
        • 1424
        Thanks guys. I just called and ordered a set from Ikerds. I used Bair's for my control arms and was happy, but I called Ikerds based on Gerard's recommendation and on the spur of the moment I ordered a replacement set from them. I got them for $325 each with new rotors riveted on and complete p-brake setup. I have to send mine in for a $200 core charge each, but I'm not emotionally attached to them.
        Mike
        • Dick W.
          • 10483
          Wonder why Bairs and Ickerd's set up together at swap meets? I think that Yogie is the source for the arms.
          Dick Whittington
          • Michael L.
            • December 15, 2006
            • 1424
            I bet you're right!
            • Jerome P.
              • October 22, 2006
              • 607
              What are your thoughts on America's Finest Corvettes at: http://www.corvetteusa.com/ ?
              Jerry
