C3 Front Suspension Finish - NCRS Discussion Boards
  • Michael B.
    • June 18, 2007
    • 400
    I pulled the front suspension down on my 1969 last night to refinish everything in preperation for San Jose. I'm sending most everything out to be stripped so that I can repaint without a POP deduction. I think I have the finishes down but if anyone would like to correct my list feel free. I also understand that different componets (frame, A-arms, brackets) may have a slightly different shade of semi gloss black.
    Upper A-Arms.........................................Semi Flat Black
    Lower A-Arms.........................................Semi Flat Black
    A-Arm Bushings.....................................Natur al
    A-Arm Pivot Shaft..................................Natural
    A-Arm Pivot Bolts & Washers.............Natural
    Lower A-Arm Mounting Bolts..............Natural
    Lower A-Arm Mounting Bolt Backing Plate...Natural
    Lower A-Arm Bumper Mounting Bracket & Bolts...Natural
    Upper Ball Joint....................................... Natural
    Lower Ball Joint....................................... Natural
    Ball Joint Rivets........................................Natu ral
    Spindle........................................... .......... .Natural
    Brake Caliper........................................... ..Semi Gloss Black with Natural at Machined Areas
    Brake Caliper Mounting Bracket............Natural
    Steering Arm............................................ Natural
    Rotor Backing Plate.................................Silver Zinc Plated
    Tie Rod Ends........................................... Natural
    Tie Rod Sleeves..................................... .Natural
    Tie Rod Sleeve Nuts & Bolts.................Natural
    Sway Bar............................................... ....Natural or Black Dip
    Sway Bar Bushing Brackets...................Semi Gloss Black
    Sway Bar Bushing Bracket Bolts...........Semi Gloss Black
    Springs........................................... ...........Natural
    Shocks............................................ ...........Gray
    Shock Mounting Bolts............................Black Phosphate
  • Michael L.
    • December 15, 2006
    • 1416
    Re: C3 Front Suspension Finish
    The best guide is what you find on the car if you believe the car to be original. With that being said, the original finish may not be discernable. I cannot swear as to the accuracy of this (not being a judge) so confirm before you commit. Here is what I know about these areas, but more complete discussions of this info can be gleaned from searching the archives for each individual topic:
    Upper A-Arms.........................................Semi Flat Black (More like a semi-gloss black, glossier than the frame)
    Lower A-Arms.........................................Semi Flat Black (see upper A-arms)
    A-Arm Bushings.....................................Natur al (correct)
    A-Arm Pivot Shaft..................................Natural (can be natural or painted semigloss)
    A-Arm Pivot Bolts & Washers.............Natural (large flat washer natural, bolt and lock washer black phosphate)
    Lower A-Arm Mounting Bolts..............Natural (Bolt and serrated washer black phosphate, stover nut cad plated)
    Lower A-Arm Mounting Bolt Backing Plate...Natural (Cad plated for plate and bolts)
    Lower A-Arm Bumper Mounting Bracket & Bolts...Natural (Cad plated ??)
    Upper Ball Joint....................................... Natural (correct)
    Lower Ball Joint....................................... Natural (correct)
    Ball Joint Rivets........................................Natu ral (correct)
    Spindle........................................... .......... .Natural (correct)
    Brake Caliper........................................... ..Semi Gloss Black with Natural at Machined Areas (low gloss, almost but not quite flat with natural at machined areas)
    Brake Caliper Mounting Bracket............Natural (Zinc plated with a chromate dip i.e. goldish)
    Steering Arm............................................ Natural (Natural or black coated from the blackout procedure
    Rotor Backing Plate.................................Silver Zinc Plated (actually silver cad plated)
    Tie Rod Ends........................................... Natural (correct)
    Tie Rod Sleeves..................................... .Natural (natural or black coated from the blackout)
    Tie Rod Sleeve Nuts & Bolts.................Natural (bolt black phosphate and nuts cad plated)
    Sway Bar............................................... ....Natural or Black Dip (correct)
    Sway Bar Bushing Brackets...................Semi Gloss Black (correct)
    Sway Bar Bushing Bracket Bolts...........Semi Gloss Black (black phosphate (?? silver cad))
    Shocks............................................ ...........Gray (blueish/gray- get the paint from Quanta)
    Shock Mounting Bolts............................Black Phosphate (see below)
    Here is more than you will ever need to know about shock hardware (lifted from a previous Joe Lucia post)
    Each shock will come with mounting hardware and bushings. For the rears, you can use the hardware, except for the lower nut and washer. The original lower shock retaining nut was much thicker than a standard nut. This nut, GM #3691530, was still available the last I checked. If you don't already have them, you might want to get some. This nut is about 3/4" thick and is phosphate coated. The nut that comes with the shock kit, which is usually a standard zinc plated nut, will function perfectly, though; it's just not the original configuration. The lower washer was not the plated, flat washer which comes with the kit. Originally, it was GM #3714310, which, the last time I checked, was still available. This washer is a plain steel(rusts), "saucer-shaped", convex washer. It should be installed with the saucer pointing OUTWARD, the opposite of what seems intuitive. You can use the lockwasher from the kit, but it is zinc plated as opposed to phosphate of the original. The original lower rubber bushings were a two-piece design, whereas the replacement shocks will come with a one-piece, already installed bushing. There is NO functional difference between the two types and it is IMPOSSIBLE to tell the difference once installed on the car. Use the bushings as installed.
    For the
    front shocks, the upper hardware is incorrect(but entirely functional). The original upper, upper grommet was GM # 3790341, which is still available. You can use the 6270752 lower, upper grommet supplied with the shock kit. You will end up with 2 left over of these if you obtain the 3790341 upper, upper grommets I described. Also, the original upper retainer was GM #3790342. This retainer is also still available last I checked. It is a large, convex-shaped "washer" with an "oil-penetrant" type finish. It is 1-29/32" outside diameter and 13/32" inside diameter. Originally, the upper shock shaft retaining nut was a 3/8-24 phosphate coated nut. The replacement provided in the kit will be a zinc plated nut. An original style nut may still be available under GM #225854.
    • Robert E.
      • April 1, 2004
      • 398
      I just checked with a local deal and one in Michigan. Both the upper shock washer (3790342) and grommet (3790341) have been discontinued. Would anyone have a line on a set for me or a lead on getting a set?
      Robert
      41801
      For the front shocks, the upper hardware is incorrect(but entirely functional). The original upper, upper grommet was GM # 3790341, which is still available. You can use the 6270752 lower, upper grommet supplied with the shock kit. You will end up with 2 left over of these if you obtain the 3790341 upper, upper grommets I described. Also, the original upper retainer was GM #3790342. This retainer is also still available last I checked. It is a large, convex-shaped "washer" with an "oil-penetrant" type finish. It is 1-29/32" outside diameter and 13/32" inside diameter. Originally, the upper shock shaft retaining nut was a 3/8-24 phosphate coated nut. The replacement provided in the kit will be a zinc plated nut. An original style nut may still be available under GM #225854.
      • Michael B.
        • June 18, 2007
        • 400
        Corvette Central has the washers but you will have to wirewheel the plating off. The grommets can bearly be seen under the washer so I just used the ones packaged with the new shocks but CC has those in a kit too.
        1965-1982SHOCK ABSORBER RETAINER WASHER - UPPER
        #572185...6.00PAIR
        1963-1982SHOCK ABSORBER MOUNT KIT - FRONT DOES 2 SHOCKS
        #581030...10.95KIT
        • James B.
          • March 1, 1985
          • 217
          Americas Finest Corvettes has reproduced the front shock absorber upper retainer (in correct finish). I saw them first-hand on my last visit there and they look great.
