Hi all i am currently having trouble with the calibration of the speedometer in my 65 .. the car has stock size tires 3.36 gears .. in the tranny i have the proper blue 20 tooth gear ,or what i belive is the proper gear . the problem is @ 55 mph the gauge reads 35 mph . were the speedos calibrated differently for different applications or were they all the same and variations made at the trans output only ?? thanks for all your help Don..
speedo calibration issues ??
Re: speedo calibration issues ??
Don,
No....The speedos were all calibrated the same. It sounds to me that the magnet in the speedcup might need to be calibrated.
I sent all my gauges out (part of it was re-calibrating the speedo) to have done by Bill at http://www.harrisonspeedometer.com/ Look up contact info and give him a call. See if there is anything else he'd recommend.
Good Luck,
David- Top
taking out the dash cluster is NOT what i wanted to do ! its a horrible job ,not a good fit for me ... that is kind of what i was thinking though that it would need to be recalibrated .. oh well i will live with it until winter , now is the time to be driving her not taking her appart ... thanks again David..
- Top
Don -- that`s quite a difference in dial reading. How about the odo or trip meter ? Is the % difference the same ? Could indicate whether the problem is in the spring cup / magnet of the speedo head, or the trans gears.
I have a few lower tooth count plastic gears at home that you could try (but I`m still in Montreal, away from Calgary for another week).- Top
