257 bulbs - NCRS Discussion Boards
257 bulbs
  • Dale S.
    • November 12, 2007
    • 1224
    257 bulbs
    Is anyone familiar with the chinese 257 bulbs? I bought 2 that were supposedly from the mid 70's, not from China. There are no markings on them at all and the bases are silver. Maybe someone took laquer thinner and cleaned the printing or numbers. Thank you Dale
    Re: 257 bulbs
    I suspect these are NOT made in the USA nor from the mid 70's. The move away from using brass to construct the base of incandescent lamps is a relatively new issue (cost reduction).
    All lamps that I've seen with silver color vs. actual brass base construction have been recently made and off-shore sourced.
    But, I would NOT automatically conclude that because the lamp has no mfgr ID marks on it and lacks a brass base that it's from China and is inferior! Former Soviet Union nations (Russia, Hungry, Romania, Etc.) are actively building 'old/obsolete' electrical components including vacuum tubes and incandescent lamps. They have the same traits as the made in China components and many are TOP DRAWER products...
    • John D.
      • December 1, 1979
      • 5507
      Re: 257 bulbs
      Dale, Real ones have a logo. For example: GE 257 on the bulb with a brass colored base. JD
      • Timothy B.
        • April 30, 1983
        • 5201
        Re: 257 bulbs
        here is a pic of the real deal GE 257.
        • Dale S.
          • November 12, 2007
          • 1224
          Re: 257 bulbs
          I think I will hook up a longivity test for one of these. I will see how long this bulb last. Dale
          • Dale S.
            • November 12, 2007
            • 1224
            Re: 257 bulbs
            The 257 bulb flahed for 15 hours. Prubably more than my original has flashed since ie was new, Dale
            • Paul J.
              • September 9, 2008
              • 2091
              Re: 257 bulbs
              That's interesting, Dale. But your test parameters are missing two real life factors. Vibration and the hot-cold cycling of actual use. I'll bet vibration has more to do with bulb life than anything else.
              It was still an intersting test, though.
              Paul
              • Dale S.
                • November 12, 2007
                • 1224
                Re: 257 bulbs
                I now have 2 spares, one brand new and on with 15 hoursand. It was going strong( even flashes and same brightness. DALE
                • John D.
                  • December 1, 1979
                  • 5507
                  Re: 257 bulbs
                  Dale, Better stock up on those China bulbs then. That's a neat test you pulled. Problem is if you fry one of those bulbs in your midyear it's a bitch to change. JD
                  • Dale S.
                    • November 12, 2007
                    • 1224
                    Re: 257 bulbs
                    John, as my original is still working, I only need one spare. Dale
                      Re: 257 bulbs
                      So, how have we concluded his lamps were made in China, John?
