Help with decoding Muncie numbers - NCRS Discussion Boards
  • Robert T.
    • May 31, 1993
    • 346
    I know my tranny is not original to the car, but out of curiosity I thought I'd check it to see where it came from. It's a Muncie close ratio 4-speed. That's the easy part. It appears to have some numbers on it that are in conflict with the "books". In particular, it has the 3885010 main case, but it has a date code of P0116. That would imply it is from a 70s car but I thought 70s used a different main case and that their date coding used letters. So I'm confused as to what this is.
    I haven't got under the car yet to see the VIN stamping. Maybe that will help clear this up.
    Can any of the tranny experts help me out?
    Bob
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: Help with decoding Muncie numbers
    No confusion with what you`ve given. The "010" means 1966 or 1967 model years. The P0116 means January 16 th of 1966, as it would be P7A16 if it was from a 1967 model year. VIN derivative should be on the exact opposite side of the assembly date stamp.
    • Robert T.
      • May 31, 1993
      • 346
      Thanks for the reply Wayne. I think I see where my confusion came from. I thought that there was a "Model Year" digit used on the 66 trannys. Consequestly I was interpreting the P0116 as a 1970 Model year, Jan 16th.
      Thanks for taking the time to reply.
      Bob
      • Tom P.
        • April 1, 1980
        • 1826
        Bob,
        IF The VIN is in fact stamped on the tranny, the first three characters will indicate the plant where the tranny was installed (letter), and 2 numbers at the beginning of the stamped VIN.
        Of those 2 numbers, one of them will be a 1(for Chev), 2(for a Pont), 3(for an Olds), 4(for a Buick). The other number will be the last number for the year model. Since the 010 case was ONLY a 66 or 67 case, then that other number will be a 6 or 7 for the year model of the car in which it was originally installed.
        • Robert T.
          • May 31, 1993
          • 346
          Thanks for the additional info Tom. I'm anxious to get up under there and read the VIN. I'm a little more familiar with the 67 stampings and I erroneously applied that standard to the 66.
          Thanks again, I appreciate the education.
          Bob
            Bob,
            Tom -
            True, unless it's from a pre-'68 Corvette - they didn't use the "GM standard format" for the transmission VIN stamp.
