Looking a set of Non-correct 15X7" Rallys. Have new set of 215-70R-15" Diamond Backs Redlines. Will these fit a 67 Coupe sm block with out clearence problems? My ol 15X6" DC wheels worked fine with this combo. But just barely. Now with 15x7's questions feasibility.
Clearance Questions
Re: Clearance Questions
It depends on which type you are talking about. Corvette 7" Rallys (-0.28" offset) will probably result in wheel well lip interference.
Monte Carlo 7" Rallys (about zero offset) might result in interference with the rear spring ends.
OE Corvette 6" Rallys (0.060" offset) are tight, but okay.
Duke- Top
Thanks to you both. Car currently has Butt Ugly Dukes of Hazzard wide Western spoke wheels. Look like 15X8"wheels? No interference. But I'm leaning towards correct 6". Hopefully without problems. The Rallys a friend has appear to be 7" Monte Carlo Date code-71 wheels. Car's a driver w/ 67 CE block.- Top
