How Much Wider? - NCRS Discussion Boards
How Much Wider?
+ More Options
Posts
  • Bill I.
    • January 29, 2008
    • 554
    How Much Wider?
    The difference between 775/75/15 and 205/75/15? Thanks, Bill.
  • Bruce B.
    • May 31, 1996
    • 2930
    Re: How Much Wider?
    Bill,
    Go to www.tirerack.com and they have a user friendly tire size comparison chart. You put in the tire size they supply the info.
      Re: How Much Wider?
      Bill -
      7.75-15's were typically 7.6" section width (although redlines and goldlines were a little wider), and 205/75-15's are typically 8.0".
      • Bill I.
        • January 29, 2008
        • 554
        Re: How Much Wider?
        John, When you refer to section width, is that the amount of rubber that meets the road? Bill.
        • Bruce B.
          • May 31, 1996
          • 2930
          Re: How Much Wider?
          John,
          See chart below from the Tire Rack website:
          Calculating Tire Dimensions
          Width x Aspect Ratio = Section Height
          Section Height x 2 = Combined Section Height
          Combined Section Height + Wheel Diameter = Tire Diameter
          Example: 185/60R14 85H or 185/60HR14
          185mm x .60=111mm
          111mm x 2=222mm
          222mm + 355.6mm(14")= 577.6mm or 22.74"
          The first number is the width of the tire in millimeters, measured from sidewall to sidewall. To convert to inches, divide by 25.4 In the example above, the width is 185mm or 7.28".
          The second number is the aspect ratio. This is a ratio of sidewall height to width. In the example above, the tire is 7.28" wide, multiply that by the aspect ratio to find the height of one sidewall. In this case, 185x0.60=111mm or 7.28"x0.60=4.36".
          The last number is the diameter of the wheel in inches.
          To figure the outside diameter of a tire, take the sidewall height and multiply by 2,(remember that the diameter is made up of 2 sidewalls, the one above the wheel, and the one below the wheel) and add the diameter of the wheel to get your answer.
          • Bill I.
            • January 29, 2008
            • 554
            Re: How Much Wider?
            Guys, all I want to know is how wide in the tire that meets the road using 205's. 6", 6&1/2" etc. Bill.
              Re: How Much Wider?
              Bill -
              You want tread width; 7.75-15's were typically about 4.6", and 205/75-15's are about 5.7", although some are wider. My Diamond Back (Firestone Supreme Si) 205/75-15's are 6.4".
              • Bill I.
                • January 29, 2008
                • 554
                Re: How Much Wider?
                Thank You John, that was what I wanted to know. Bill
