'63 Production Sequence vs. Engine Casting - NCRS Discussion Boards
    Re: '63 Production Sequence vs. Engine Casting
    Thanks for the info John! With 55,000 castings going to Flint daily I assume Flint machined, assembled, and shipped that many daily. Those are significant numbers for each plant.
    How large were these facilities? I assume 3 shifts, did the foundry operate 7 days or the furnaces just stayed hot over the weekend? How many employees?
    Thanks again for sharing your knowledge.
    Steve
    Steve -
    Flint V-8 employed about 6,000 people, and covered over two million square feet; the machining department worked three shifts, and assembly worked two shifts. There were two assembly lines - Line #1 ran at 180 per hour, and Line #2 ran at 120-140 per hour.
    Mark Gorney can provide the numbers for the Saginaw Foundry (now called Saginaw Metal Casting Operations); he's been there for 38 years and has lots of history.
    • Steven B.
      • June 30, 1982
      • 3995
      #32
      Steve -
      Thanks John! From '74-'76 I worked at Maremont Corp. in Paulding, Ohioas prod. supv and prod control. We mfg'd brake linings and clutch facings. At one time Maremont, marketed under the Grizzly name, had a white '59 or '60 test car assigned to engineering. There was a GM foundry in Defiance, Ohio a few miles away then. Do you know what they produced?
      Steve
        Steve
        Not offhand, but I believe Joe Lucia is quite familiar with that particular foundry and its products.
