L84 fuel percolation - NCRS Discussion Boards
  • Michael G.
    • November 12, 2008
    • 2157
    Is the actual fuel percolation in an L84 engine taking place in the spider tubing? Can I eliminate it by cooling the spider? (I've already tried 100 Low lead aviation fuel without success.
    Mike
    1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
    1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
  • Jack C.
    • September 30, 1992
    • 1090
    Re: L84 fuel percolation
    Did you try to wire the heat riser to the open position?
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
      • 15706
      Rochester FI engines have no heat riser passage through the manifold/baseplate and no heat riser valve.
