My 2000 power windows work intermittently - the pass. is better than the driver's. It seems like a loose connection but I do not know wherer to start.
2000 Power Windows
Re: 2000 Power Windows
Darold, Our 2000 was rewired by the dealer at 50,000 miles. Resoldered both doors inside. Recently the power door locks are intermittent. Bet you 1957 does not have these problems, Progress, you say. Looking forward to seeing you in July at the Nats.
Scott Sinclair
- Top
Scott Sinclair
Door lock modules seem to be the guilty culprit most times for me on the C5 power lock issues.Tom Hendricks
Proud Member NCRS #23758
NCM Founding Member # 1143
Specialist for 27 years at BUDS Chevrolet.- Top
if the wring is good going thru the door post and the door they say that the commutators in the motors get glazed up and cause this problem. they say you should run your windows up and down every time you drive the car to help prevent this- Top
