'66 Hubcap paint - NCRS Discussion Boards
'66 Hubcap paint
  • Loren L.
    • April 30, 1976
    • 4104
    '66 Hubcap paint
    The '66 Judging Manual I have (probably not the latest) calls out the paint on the hubcap as Charcoal - I think that the color mine have would be closer to "Flat Black". Comments?
  • Jim V.
    • November 1, 1991
    • 587
    Re: '66 Hubcap paint
    Original more like dark silver (same as KH KO). Many refinished and repros with black.
    • Michael G.
      • January 1, 1997
      • 1251
      Loren,
      I like dark Cast Blast.....Plasti Cote.
      Michael G.
      • Mark W.
        • February 1, 2001
        • 160
        Loren, for my '66 wheel covers I got the Long Island Corvette 65-66 Hubcap Dark Gray spray paint (#45-25). I took each wheel cover apart (replaced the plastic inserts), washed them thoroughly with soapy water to get all dirt and grease off. Spent at least an hour on each one masking off everything except area to be painted. Sprayed a few light coats of self etching primer, then several light coats of color, letting each coat dry for several minutes before the next coat. I did my wheels more than 4 years ago, I've driven over 7k miles and the wheel covers still look great.
        • Jeff A.
          • November 1, 2005
          • 199
          The only thing I did in addition to Mark's procedure was to lay a light base of textured paint (Rustoleum, as I recall) before applying the LI hubcap paint. The original finish had a slight texture.
          Good luck!
