Mystery wheel rim - NCRS Discussion Boards
Mystery wheel rim
  • Bob R.
    • June 30, 2002
    • 1595
    Mystery wheel rim
    I have a rim I am trying to identify. It has to be from the 50's but I don't know the correct application. The size is 15 x 5 the lug spacing is 4 1/2" The rim has nubs around the perimeter to hold the wheel cover on. The center section is revited to the outer section. The valve stem is a larger diameter. The only id I see ont he rim is the letter "M" or "W". Does anyone know what car it is for?
  • William C.
    • May 31, 1975
    • 6037
    Re: Mystery wheel rim
    I believe Chrysler products used a 4 1/2 inch bolt circle,"Back in the Day"
    Bill Clupper #618
    • Bob R.
      • June 30, 2002
      • 1595
      It fits the chevy bolt pattern on my 63.
      • Doug F.
        • November 1, 1983
        • 322
        70 chevy used a 15 x 5 wheel that worked great with a radial tire for a spare in a mid year, i used to have standing order at my local junk yard, don't remember if they were welded or riveted, but it sure looks familiar.
        • William C.
          • May 31, 1975
          • 6037
          If it fits the '63, the bolt circle is 4 3/4, not 4 1/2.
          Bill Clupper #618
          • Bob R.
            • June 30, 2002
            • 1595
            It must be 4 3/4" then because it does fit the 63.
            • Mike E.
              • February 28, 1975
              • 5138
              Looks like a 55-56 passenger car wheel to me. Riveted. 15x5 Incorrect profile on the center section for Corvette. Large valve stem hole. No double bumps next to the valve stem hole. Bumps along the outside for wheel cover retention. 55-56 Passenger car.
              • Bob R.
                • June 30, 2002
                • 1595
                Thanks to all for there assistance
