Source for correct C1 oil fill cap? - NCRS Discussion Boards
  • Bruce B.
    • May 31, 1996
    • 2930
    Re: Source for correct C1 oil fill cap?
    Lee,
    Here is my understanding of cap markings:
    56 to 58: "OIL OIL" with a straight indentation between the text.
    59 to early 61: "OIL OIL" with a half moon indentation between the text.
    late 61 to 62: "OIL AC" with a half moon indentation between the text.
    As far as rivits go, the one I believe on Roys cap appears to not be rounded (like a button head) or flat like the Gene Smith cap. It looks like it has a low spot in the middle. Which is like a number of original caps I have. I'll try and get a picture of one.
    Bruce B
    • Bruce B.
      • May 31, 1996
      • 2930
      Lee,
      Here is what I think is the correct rivit and top configuration for a 56 thru 58 Corvette. The rivit I believe looks like Roys.
      I don't have a 59-60 cap, or at least I can't find it.
      • Florian W.
        • September 10, 2007
        • 50
        Thanks to all the responses and a section in the Supplement section of N.Adam's book, I now know that what I need is a '59 or '60 version of p/n 1552719. Unfortunately, there doesn't appear to be a good reproduction of this particular part, so I'll just have to keep looking for an original.
        Thanks for the help.
        Lee
        • Jack H.
          • April 1, 1990
          • 9906
          Keep looking or do what others have done... Dig up an original from a scrap yard car. Expect the top to be dented from prior owner 'push on' cycles.
          Now, de-crimp the top cover from the base. Remove the top cover and gently tap out the dent(s). Then, re-assemble the cover to the base.
          One word of caution here, finding that non-vented version of the oil cap is going to be CHALLENGING because most of the passenger cars used the vented version with their hydraulic vs. solid lifter engines...
          • Roy B.
            • February 1, 1975
            • 7044
            Or if dents are small use BONDO then sand and repaint.
            • John F.
              • March 23, 2008
              • 2418
              On my 62 the wire stuffing or whatever it's called is gone. It has the holes for venting but nothing in there. What was the material inside?
              • Bruce B.
                • May 31, 1996
                • 2930
                John, I believe in the original caps the "stuffing" is like steel turnings as from a lathe.
                Some of the repros use a material similar to the copper or brass scrubing pads like my mother used to use.
                It looks similar except it is not steel.
                Bruce B
                • Steven B.
                  • June 30, 1982
                  • 4009
                  John, years ago I found abrasive pads at a large hardware store that was a very close match. I don't know if it is still available but worth a try. I have seen both steel and aluminum.
                  Good Luck!
                  Steve
                  • John F.
                    • March 23, 2008
                    • 2418
                    #24
                    Thanks guys. I appreciate the input!
                    • John F.
                      • March 23, 2008
                      • 2418
                      #25
                      Dollar General had the abrasion pads for a $1.25. Cut off a bit and stuffed it in. Good as new now. See pics.
                      • Steven B.
                        • June 30, 1982
                        • 4009
                        #26
                        John, very good job!
                        Steve
