C1 Transmission Tunnel - NCRS Discussion Boards
  • Mark P.
    • May 13, 2008
    • 934
    Does anyone know if repro's are available for this part ?
    Anyone know the size rivits and material (i.e. aluminum) that attach it ?
    My 1960 is missing it.
    Re: C1 Transmission Tunnel
    You might try Grossmueller's or Mary Jo, or Paragon Vintage might have a hulk they can remove one from.
    • Doug F.
      • November 1, 1983
      • 322
      Josh, just looked at a couple of bodys and it looks like it just uses the standard aluminum button headed 3/16' rivet thats used all over the car, such as center seat belt ret plate, cowl vent accurater nut plate, main soft top mount bar ect.
      • Stewart A.
        • April 16, 2008
        • 1035
        Mark, that looks like a pretty good template to use. Why not try and make 2 I'll buy the other one off you ? I'm surprised it's made of alloy, it's not real strong. Stewy
        • Jerry C.
          • November 1, 1995
          • 741
          Corvette Central has this part.
          • Edward M.
            • November 1, 1985
            • 1916
            Do you need the tunnel cover, or just the reinforcement shield?
            • Doug F.
              • November 1, 1983
              • 322
              the time i broke a ujoint in my 59 i was glad it was there, but 61 and 62 never used it, so it must not be necessary.
              • Mark P.
                • May 13, 2008
                • 934
                I just need the metal shield. Corvette Central has the fiberglass tunnel which I don't need.
                If anyone knows of a repro metal shield please let me know.
                I'll reach out to the used part vendors to see if they have one.
                • Edward M.
                  • November 1, 1985
                  • 1916
                  Corvette Central
                  1956-1962DRIVE SHAFT SHIELD - UNDERBODY METAL U JOINT 231001 42.25 EACH
                  • Mark P.
                    • May 13, 2008
                    • 934
                    Ed - thanks for that ! I could not get it to come up in any of my searches for "Transmission", "Trans" and "Shield".
                    Sometimes the CC search function is not always 100% reliable.
                    Mark
                    • Edward M.
                      • November 1, 1985
                      • 1916
                      Mark
                      Tell me about it. They call it a Driveshaft shield. Good luck on your car.
