I need some technical questions answered regarding my early 57 corvette. I have had it judged at two regionals and now plan to go to a national meet and I am trying to pick off some of the small items I have been docked on so far.
1. I have two holes in the left inner fender where the washer bag was mounted. I do not have the washer option and one hole is used for a bracket for the wire harness and the other is empty. Should the one hole be empty or not there?
2. I was told that my bell housing should be painted. Is this true for the automatic? My housing and tranny are painted cast iron color.
3. I have dual 4 carbs with an alum intake. I have the cast iron thermo housing 3705018. What color should it be?
4. On the heater control lever on the firewall area. Should there be a clip on the arm to hold the cable from coming off or does the cable just slip over the arm?
Thanks for all of your help and expertise. I really do enjoy the judging process and look forward to seeing everyone in San Jose.
Craig
Craig
