Texas Regional in Killeen - NCRS Discussion Boards
  • Guest
    Hey youse Tejanos!
    Sent my registration in the mail yesterday and will be flapping in from Balmer - thinking it is best to fly in to Austin and drive? Or what would youse all suggest?
  • Gary C.
    Administrator
    • October 1, 1982
    • 17940
    Re: Texas Regional in Killeen
    Rickman, it's 3 hrs from DFW or Love Field (Southwest Airlines) and 1 1/2 hrs from Austin. Austin has lower volume # of flights, but also does SWAL. Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Jean C.
      • June 30, 2003
      • 688
      Rick, thanks for registering.
      I am sure you will have adequate flight options if you use Austin as your arrival/departure point. Killeen is North of Austin; however, the Austin airport is South of Austin but that should not be a problem. I-35 all the way from near the airport to Killeen.
      Dallas/Ft. Worth Airport is another option although a longer drive, also on I-35.
      Per Google Maps:
      DFW to Killeen = 2.5 hrs, 154 miles
      Austin to Killeen = 1.5 hrs, 87 miles
      Best regards,
      • Guest
        Charlie and Gary,
        thanks for the quick responses! very familiar with I-35, as used to run that at least once a year on my way to Minnesota from San Antonio
        • Mike L.
          • January 1, 1986
          • 313
          No easy way there from Connecticut!!!!!!!!!!!!
          • Guest
            Mike,
            drive to Balmer and then fly into Austin! around $360 round trip and both ways are non-stop
            • Michael L.
              • July 31, 2005
              • 562
              Former Chef of mine is at Shilo Suites in Killeen, he used to put out some nice food. Might want to check out their restaurant and Ask for Chef Montgomery...
              • Frank C.
                • August 31, 2003
                • 171
                I am stationed at Ft Hood and the Killeen area. Another route to consider is to fly directly into Killeen Airport. Research flights using the "GRK" Airport code.
                Frank
                • Guest
                  Frank,
                  my son was stationed at Ft Hood and he suggested Austin - said "real tiny" planes fly into Killeen
                  • Guest
                    Michael,
                    thanks for the info on the chef - my biggest concern is that the hotel bar has LOTS of Makers Mark on their shelves
                    • Frank C.
                      • August 31, 2003
                      • 171
                      Rick,
                      The Ft Hood Area Airport has been expanded, and is taking larger airplanes. Check the airplane size when considering booking options. Flight time for the connections from any of the connecting airports is only 30-45 minutes. Connections are made at either Houston, Austin or Dallas depending on carrier. My wife and I have been staioned here since 2000, and have flown many times using Austin and Killeen. We without any hesitation recommend flying direct.
                      Frank
                      • Guest
                        Frank,
                        thanks for the vote of confidence - but, already booked non-stop flight into Austin via Southwest for $360.00 - will drive up to Killeen
                        • Tom S.
                          • March 1, 2004
                          • 1087
                          I was there in1969 for about a month before returning to Viet Nam for my second tour. That was better than spending another day in the 2nd. Armored Div. or Ft. Hood for that matter. That place was a hell hole back then...Tom Stanton
