67 U-joints - NCRS Discussion Boards
67 U-joints
+ More Options
Posts
  • Thomas N.
    • July 31, 2002
    • 402
    67 U-joints
    Hi:
    On a 67, does the u-joints for the driveshaft from the transmission to the rear end have zerk fittings? Thanks!
    NCRS New England Chapter Chairman 2022, 2024
    N E Regional Chairman 2024
    1967 Corvette Convertible Under Restoration
    1996 Corvette Coupe NCRS Chapter Top Flight 99.5, NCRS National Top Flight 100.0
  • Chris E.
    • November 3, 2006
    • 1335
    Re: 67 U-joints
    For sure not on the driveshaft, and I believe also not on the half shafts. Someone else can chime in on the half shafts to double check me there.
    Chris Enstrom
    2011 Z06, red/red
      • 43259
      Re: 67 U-joints
      Chris and Thomas-----
      There are never any grease fittings on 63-79 half shaft u-joints. The vast majority of driveshaft u-joints have no grease fittings, either. However, I have seen a few 63-69 driveshaft u-joints which I believed to be original which did have grease fittings. I would certainly say, though, that driveshaft u-joints with grease fittings are not "typical of factory production". So, unless one is replacing a known-original u-joint which does have grese fittings, I would use the type without grease fittings to be consistent with "typical factory production".
