Clutch Return Spring - NCRS Discussion Boards
  • Paul A.
    • October 26, 2008
    • 2
    Hi Everyone, this is my first visit, I own a 1962 with a 4 speed. My question is. Can anyone tell me how to hook the clutch return spring from the frame to the linkage. Pulling on that spring is a good workout, But there must be an easy way.
  • Susan G.
    • May 31, 2005
    • 136
    Re: Clutch Return Spring
    Hi Paul, if your car is like my 58 with a monster spring, you need to make a tool which bolts to the frame which will pull the spring and allow you to attach it. I have exact instructions on how to make the tool. Please send me a fax number and I will send it to you. There is no other way to pull the spring as far as I know. Regards Susan
    • Rob M.
      NCRS IT Developer
      • January 1, 2004
      • 12799
      Put little plates of metal (1" x 1") between each winding by bending the spring each time. The spring can be stretched this way without much force until it is long enough to attach.
      regards,
      Rob.
      Rob.
      NCRS Software Developer
      • Gary B.
        • September 30, 1987
        • 305
        Robs way works. Years ago I remember just using a long screw driver and muscle.
        • Joel T.
          • April 30, 2005
          • 765
          I did this once on a 1961... if I recall correctly, I also "unadjusted" the clutch and used a prybar to get the spring on.
          Hopefully memory serves!
          Joel
          • Bill M.
            • April 1, 1977
            • 1386
            Folks:
            Use a crescent wrench on the clutch cross-shaft lever. ST-12 p. 6R-9.
            • Edward B.
              • January 1, 1988
              • 537
              Originally posted by Bill Mashinter (1350)
              Folks:
              Very simple and works well - although not considered manly, it never hurts to read the instructions.
              • Bill B.
                • December 1, 1993
                • 192
                I use my brake spring removal tool, it works perfectly every time.
                Bill
                1961 Black/Silver/Red Int. 283/315 FI
                power windows. Frame off 65% completed.
                1989 White/hard top/Grey Int. daily driver 167,000 miles
                "The problem with Liberalism is that eventually you run out of other people's money" - Margaret Thatcher
                • Christopher R.
                  • March 31, 1975
                  • 1599
                  Wear safety glasses when you do this.
                  • Philip C.
                    • December 1, 1984
                    • 1117
                    Hi Paul all you have to do is disconnect the two clutch rods from the Z bar, back up the Z bar, hook the spring to it, using an adjustable wrench on the Z bar lever ( the one that clutch fork rod goes to) and lever it over center and you done, no tools, no 2x4s, no cranes, cable winches, takes 10 seconds Phil 8063
