C-2 Wiper motor problem - NCRS Discussion Boards
  • Herb F.
    Infrequent User
    • February 25, 2008
    • 7
    The windshield wiper motor on my '63 won't go to park position. Can anyone direct me to an internal wiring diagram so that I can troubleshoot this problem? Thank in advance for your help. Herb
  • Rich P.
    • January 12, 2009
    • 1361
    Re: C-2 Wiper motor problem
    Herb,
    if your switch is bad it would cause this problem. Otherwise this usually happens because the grease in the motor has dried out and needs to be replaced. Not a hard job. you need to remove the washer pump and cover then clean the old grease out and regrease.
    Rich
    • Herb F.
      Infrequent User
      • February 25, 2008
      • 7
      Thanks Rick: I have already had the motor apart, cleaned and lubed while doing the restoration of the car. Every thing was working OK until the wipers failed to park. I have already removed the washer pump assembly, but I need a wiring diagram to troubleshoot where the problem is located. It doesn't look too complicated, but I don't want to disassemble any more than is necessary to repair the problem. Thanks again. Herb
      • Rich P.
        • January 12, 2009
        • 1361
        Herb,
        If I remember correctly the 63, 64, 65, 66 and 67 Service Manuals have the Diagrams in them If no one can post that for you I gould try to take a picture of it and try to post it.
        Rich
        • Herb F.
          Infrequent User
          • February 25, 2008
          • 7
          Rick: Anything you that you could post showing the internal wiring of the wiper motor would be appreciated. Thanks Herb
            Open your copy of the 1963 Corvette Shop Manual to Electrical-Body & Chassis, Section 12-15. You'll find the WS wiper motor overhaul and diagnosis described including a problem/remedy troubleshooting guide at the rear of the section...
            • Herb F.
              Infrequent User
              • February 25, 2008
              • 7
              Thanks Jack: I was hoping to find something "on line" but I guess I will have to break down and purchase a shop manual. Thanks again - Herb
