67 Signal Switch, It's all in the cam, part 2 - NCRS Discussion Boards
  • Gerard F.
    • June 30, 2004
    • 3805
    Re: 67 Signal Switch, It's all in the cam, part 2
    Originally posted by Gary Jaynes (3503)
    Jerry, have you tried ordering one from NAPA to see if there any difference in the ones you already have. I don't know but it could or could not be foreign junk!
    Gary,
    The new one I got from Shee-Mar seems to be working just fine. I recently had to change to this one, the day before I joined the road tour to the San Jose National. Worked just great for the trip.
    Also have heard that the Lectric Limited one works fine.
    One trick I learned, is to use a shorter lever mounting screw with a lockwasher (where the lever mounts to the switch cam). I used a #8-32 1/2" screw where the original is a 3/4". This seems to hold the cam to the switch a lot tighter for better contact. Found that with the original screw, the lever, and thus the cam on the switch, was somewhat loose fore and aft, giving you a poor contact between the tangs on the cam and contacts on the switch.
    Jerry Fuccillo
