All,
I just pulled the fuel pump on my '65 for the second time in 10 yrs. Both failures have been due to the lever arm spring that has broken. It seems to me that this spring should last much longer than this. I have seen others post that they, too, have had this spring break causing fuel pump failure. Has anyone researched a stronger, longer lasting spring for this application. My guess is that the current rebuild spring is some cheap piece of junk from China. After I put this pump in I don't want to do this job for a long time as it really is a pain in the you-know-what. Thanks.
George Jerome Jr
#31887
George Jerome Jr
#31887
