Valve Seals - NCRS Discussion Boards
Valve Seals
  • Rob M.
    • April 30, 2003
    • 657
    Valve Seals
    I am looking to replace the valve seals for my '66 327/300 and I would appreciate any recommendations for new valve seals - manufacturer, part number, cost, etc. Thanks in advance.
    Rob
    '66 327/300 Regional Top Flt
    '08 6 speed coupe
    • 11698
    Re: Valve Seals
    I just installed a set of Fel-Pros which are available as a kit from virtually any auto parts store at $10-15/set. They look just like the originals - except they're not rock hard or falling apart.
    Patrick
    • Michael G.
      • January 1, 1997
      • 1251
      Re: Valve Seals
      Rob,
      Many brands and different styles....you may get numerous opinions. Go to the person(s) who builds engines for a living, see what they would recommend. All valves seals are not created equal..
      Michael G.
      • Rob M.
        • April 30, 2003
        • 657
        Re: Valve Seals
        Patrick and Michael,
        I appreciate your responses. I am sure that there are many opinions and not all valve seals are created equally. I will ask an engine builder that I know, but thought the collective wisdom on the board would guide me in the right direction.
        Rob
        '08 6 speed coupe
          • 11698
          Re: Valve Seals
          I'd suspect that "most" of the plain-looking O-ring type are made by a small number of companies, and the rest are just repackaged and sold. That's why I went with the Fel-Pro ones. Well, that and I already had 2 sets on hand that came in engine gasket kits.
          Patrick
            • 43288
            Re: Valve Seals
            Rob-----
            The stock-type seals will work well IF they are properly installed and with metal shields also installed. Of course, for these or any valve selas to work properly, the valve guides and valve stems have to be within tolerance.
            If you want to improve sealing, also install positive type valve seals on the INTAKE valves. Use GM #460483 or equivalent.
