1970 Wiper Arms - NCRS Discussion Boards
1970 Wiper Arms
  • Les G.
    • December 5, 2008
    • 158
    1970 Wiper Arms
    I Have The Original Wiper Arms On My 1970, Only One Clip On The Drivers Side Is Holding The Metal Washer Tube To The Arm. I Order A New Set Of Clips But I Am Trying To Find The Correct Position Of These Clips And Which Clips Go Where.
  • Paul O.
    • August 31, 1990
    • 1716
    Re: 1970 Wiper Arms
    Les the larger clips attach to the flat part of the arm between the upper where the bend is and the lower section about 4-5 inches apart. The smaller clips attach to the lower section on the under side there are 2 small opening in the bottom plate. The top part of the tube is soldered to a small bracket riveted to the arm. Paul 18046
      • 3415
      Re: 1970 Wiper Arms
      Hi Les,
      In addition to Paul's information, I found the diagram for the clips' placements in the Paragon Catalogue and on their site to be a big help.
