Turn Signal Connectors - NCRS Discussion Boards
  • Murray S.
    • May 31, 1990
    • 75
    I recently purchased 2 Original front turn signals for my 65 Corvette. When I was trying to install them, I found that the male rubber connector that plugs into the main wiring harness was not very pliable; I was unable to make the connection.
    Does anyone know of a method of "softening" the connector without destroying it?
    I have tried using WD-40 with little success.
  • Paul Y.
    • September 30, 1982
    • 570
    Re: Turn Signal Connectors
    Pure silicone grease works good for me. It also protects the contacts. Unless of course the hardness is from age and UV rays. Then it will just make it a bit more slippery and that might help. Paul
    It's a good life!
    • Donald T.
      • September 30, 2002
      • 1319
      Believe it or not, dish soap works pretty well.
