60-70 Fan Clutch CK #3916141 R - NCRS Discussion Boards
  • Gerard F.
    • June 30, 2004
    • 3806
    Is their any operational problems with running a CK fan clutch on 67 small block without factory AC.
    As noted in the 67 Judging Guide, a small block should have a CJ fan clutch which has a shaft length of 1.8", whereas a CK has a shaft length of 1.5".
    Seems to me that this would put the fan with the CJ clutch , some .3" closer to the the shroud and radiator. Would this make the cooling any better, and is it worth getting or making a spacer for the .3".
    Or is it not worth worrying about.
    Jerry Fuccillo
    • 43258
    Re: 60-70 Fan Clutch CK #3916141 R
    Jerry-----
    I would say it's no problem, at all, using the 3916141 as a direct replacement. In fact, GM has for over 25 years cataloged the 3916141 as the SERVICE fan clutch for ALL 1960-70 Corvette applications.
      Jerry -
      I've had a 3916141 on my '67 SB for seven years, works fine.
      • Gerard F.
        • June 30, 2004
        • 3806
        Thanks, Joe, John,
        I have one coming in preparation for the road tour. Will be meeting the eastern tour in Barstow in July.
        Had the water pump redone and the orig radiator/block flushed last year. I think the original fan clutch is still on.
        Last weekend from Tahoe to Sonora, I hit some 100d heat at the lower elevations. It held to between 180-190 while I was cruising, but when I had to slow down going through the towns, it when up to 210 on the gauge, but actually felt a little hotter.
        Thought I'd do the road tour with a new fan clutch. (But the original one will be in my luggage, just in case)
        See you in San Jose,
        Jerry Fuccillo
