1970 Tilt Telescope problem - NCRS Discussion Boards
  • Stephen B.
    • April 1, 1988
    • 879
    I've had my tilt-tele apart to repair the typical wobble. The steering shaft housing screws were tight, and the pivot pins are snug. What else could be creating the wobble?
    • 6956
    Re: 1970 Tilt Telescope problem
    Steve, Maybe The Lower Bearing On The Column Or The Preload On The Lower Bearing. I Beleive You Can Look At The Play Outside In The Engine Compartment While Having Someone Wiggle The Steering Wheel , Theres Not To Much Else That Can Cause Excessive Play In Column. Since You Had The Upper Column Apart I Assume The Upper Bearing And Race Are Good. Thanks Ed
    • Dick W.
      • 10483
      Loose nut behind the steering wheel (The Devil made me do it)
      Dick Whittington
      • Joel A.
        • September 30, 1997
        • 214
        Not sure what you're calling the steering shaft housing bolts, but these are the ones that normally let the tilt flop. This is the best pic I can come up with at the time, but there are three fasteners. Those are always the ones I find loose when I have a floppy wheel...I mean, besides the one behind the wheel. If these are the ones you're talking about, then Ida know...
        Joel Adams
        1974 Coupe
        1985 Coupe
        "I know the voices aren't real...but sometimes they have some really kewl ideas...."
        • Jim S.
          • August 31, 2001
          • 730
          Here is a link to my T&T Disassembly & Repair Paper #1 in word.doc format. Pages 2 & 3 describe a number of quick tests that can be conducted on the column while it is still in the car.
          BTW, the paper is also available in pdf format at the www.corvettefaq.com websight.
          Jim
            Check the pivot pin area again... The 'typical' cause for looseness is the 'fat American' syndrome--prior owners used the steering wheel in its fully upright position to HOIST their body up and out of the car.
            That resulted in side loading pressure on the housing at the pivot pin interface causing the holes in the housing to enlongate around the harder steel pivot pins. The general direction of 'slop' from this syndrome is in the wheel's 10:00 to 4:00 position duplicating the cockpit exit stress.
            If that's you problem (pretty common) you have two alteratives:
            (1) Remove the pivot pins + housing and have a competent machinest hand craft and install bushings to eliminate the wear in the housing.
            (2) Seek a scrap yard car from the era with equivalent TT steering wheel (e.g. Caddy, Buick) and use it as a donor for a fresh, low wear, housing to replace your existing but worn part.
            • Stephen B.
              • April 1, 1988
              • 879
              I shall analyze the wobble over the weekend and report my findings.
              • Stephen B.
                • April 1, 1988
                • 879
                The 4th gear lock housing was welded as a repair. I'll have to find used parts to eliminate the wobble. Thanks for all of your help.
