1958 245 vs 270 2X4 - NCRS Discussion Boards
1958 245 vs 270 2X4
  • David L.
    • December 1, 1981
    • 116
    1958 245 vs 270 2X4
    I am curious about the current availability of 245 HP vs 270 HP carburetors for a 1958. Also price differential. Is one set-up harder to find and more expensive than the other?
    I am speaking of the carburetors only, restored and ready to bolt on and tune. Thanks!
    David
  • Steven B.
    • June 30, 1982
    • 4011
    Re: 1958 245 vs 270 2X4
    David, check the current and past Drivelines. Chuck Smith and Bob Kunz advertise and sell the units. Contact info. is in the Driveline.
    Steve
    • Pancho T.
      • July 31, 1993
      • 238
      they are both really hard to find
      • David L.
        • December 1, 1981
        • 116
        Thanks! Guess I'll go with 270 hp since availability and cost appear to be equal for a restored set.
        David
        • Mark P.
          • May 13, 2008
          • 951
          Any opinions on the driveability of a 245 HP vs 270 HP set ? Are they comparable ?
          • Joel T.
            • April 30, 2005
            • 765
            David
            Dave;
            I bought a "correct" set for a 1961 which I had a while back; cost me over $3K. You can get "clones" for a heck of a lot less than that. I suspect that the 1961's are not materially different than your 1958's
            The major difference, as I understand it, between the 270 and 245 versions is the length of the weight arm on the secondaries. The 245 has shorter weights and is designed to open up at a lower RPM. In contrast, the 270 version have longer weight arms.. Keep in mind that cams are also different in the two motors; 245 being hydraulic while 270 is solid a solid lifter motor hence the RPM differences.
            I got mine from Phil Cancella at Customer Rebuilt Crabs here in NJ. Phil has a web site where you can check him out. On the 1961's (and perhaps on the 1958's as well) I was told that I could start with a 245 set and then have them converted to 270's.... I was going to build out a new 270 motor for my 245 car so this was a consideration for me.
            Good luck,
            Joel
            • David L.
              • December 1, 1981
              • 116
              Joel,
              Thanks for the additional information. This and what has been contributed earlier will definitely help me with my project. By the way, the car is a 4-speed, Panama Yellow, white cove and top .. has both tops .. and charcol interior. Bought the car in 1981. The engine is the final major part. Might say a 28-year on and off restoration project.
              David
              • Steven B.
                • June 30, 1982
                • 4011
                Mark, I have built and driven both. Maintenance is no problem on either---on the 270 adjust valves once in a great while as it is not a daily driver. For driving I enjoyed the 270 more as the sound and acceleration are a bit more. On either you can adjust the linkage so the front carb kicks in quicker.
                Steve
