Need help with 55 3 speed Saginaw Transmission ID - NCRS Discussion Boards
  • Gary C.
    Administrator
    • October 1, 1982
    • 17771
    Re: Need help with 55 3 speed Saginaw Transmission ID
    William, if the price is right and you can use some of the parts I'd at least check the gear set to see if it's close ratio or not. Here's link to the referenced post. Best, Gary....
    https://www.forums.ncrs.org/showthre...15183&uid=3557
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Karl L.
      • February 1, 1977
      • 174
      Some pick-up trucks had a different bolting setup Trans to Bel Housing.
      Upper bolts thru the trans ears and screwed into Belhousing.
      Lower bolts went thru inside housing and screwed into the lower ears of the transmission.
      Karl
