67 rear leaf spring done - thoughts? - NCRS Discussion Boards
  • Chris E.
    • November 3, 2006
    • 1326
    Need to do a little paint touch up, but it is pretty much done.
    Chris Enstrom
    2011 Z06, red/red
  • Stephen L.
    • May 31, 1984
    • 3157
    Re: 67 rear leaf spring done - thoughts?
    Recommend installing new insulating strips.
    Yours appear to be a little ragged.........
    If some of yours are in good shape but could be used in a "shorter location" then just purchase the long ones and cut the old ones for the short locations.
    I've attached a photo of my spring with new & used liners.......
    • Ray G.
      • May 31, 1986
      • 1189
      Hello Chris;
      How about having the rubber bushing retainers pressed in and folded over properly?
      Hope this helps.
      Ray
      I hope you dance
      • Gary B.
        • February 1, 1997
        • 7023
        '67 rear leaf spring liners
        Stephen,
        I suspect Chris' liners are new. I've seen NOS springs with ragged edges on a few of the liners. They just tend to get scraped up.
        Chris, what's the build date of your car?
        Gary
        • Stephen L.
          • May 31, 1984
          • 3157
          Gary, Most of my spring liners are original. I purchased 2 new ones and then used the other by cutting them off for the shorter requirements. As you can see, they aren't ragged. Once installed on the car the edges should remain intact, as there is typically nothing to wear on the edges.
          Chris, I used a large ball peen hammer to spread the rubber cup holders onto the spring. Just place the ball in the hole and strike with a mall hammer. Support the other side of the cup when doing this
          • Gary B.
            • February 1, 1997
            • 7023
            Crimping retainer cups on '63-'80 rear springs
            Chris,
            Although a ball peen hammer will work, I've made a new tool which will do the crimping in a simple and controlled way. The tooling will be shown in an article to appear in the next issue of the Restorer. I loan out the tooling for up to 2-weeks, but basically I ask the lender to pay my postage & insurance costs and a nominal charge for depreciation.
            Gary
            • Chris E.
              • November 3, 2006
              • 1326
              Stephen,
              I took the pictures showing the "bad" side. That will face forward when installed. The other side of the insulating strips are better. Thanks for the advice.
              Chris
              Chris Enstrom
              2011 Z06, red/red
              • Chris E.
                • November 3, 2006
                • 1326
                Originally posted by Ray Geiger (9992)
                Hello Chris;
                Hope this helps.
                Ray
                Ray, haven't gotten there yet. Also, what finish are the retainers, cad or zinc or phos? (don't have my TIM/JG in front of me)
                Chris Enstrom
                2011 Z06, red/red
                • Chris E.
                  • November 3, 2006
                  • 1326
                  Re: '67 rear leaf spring liners
                  Originally posted by Gary Beaupre (28818)
                  Stephen,
                  Gary
                  Gary, the spring is from 1988, as are the liners. (they came together as a complete unit)
                  Build date of the car is early, Sept 66. (VIN100183)
                  Chris Enstrom
                  2011 Z06, red/red
                  • Gary B.
                    • February 1, 1997
                    • 7023
                    '67 retainers
                    Chris,
                    The retainers were natural steel; unplated and unpainted. Do you know if your car came with the early style (shallow sloped lip) retainers or the current style (steeply sloped lip)? The change-over happened during the first part of the '67 model year, with some early '67s, like yours, using the old style or a mix of old and new style.
                    As an aside, the current GM service replacement retainer now appears to be nickel plated, and too bright to pass for original. It's an easy matter to strip off the plating with diluted muriatic acid and then smooth out the finish using 0000 steel wool to match the original, bare steel look.
                    If you want to know more about the geometry difference between the old and new style of retainers, see my article in the Restorer from 3, 4 or 5 (time flies) years ago. I don't recall the issue exactly, but you could e-mail me at garybeaupre@comcast.net and then I can send you a PDF of the article.
                    Gary
                      • 11643
                      Originally posted by Chris Enstrom (46481)
                      Stephen,
                      Chris
                      I think you may have the wrong liners. Look at the ones in Steve's picture.
                      Patrick
                      • Gary B.
                        • February 1, 1997
                        • 7023
                        Retainers; correction
                        Chris,
                        I was getting my spring articles confused. The one that included the retainer info was co-written by me and Joe Lucia. Let me know if you want a PDF version.
                        Gary
                        • Chris E.
                          • November 3, 2006
                          • 1326
                          Re: Retainers; correction
                          Chris,
                          Gary
                          Gary, if you would be so kind as to email me a copy of that, I'd appreciate it.
                          censtrom@comcast.net
                          Also, thanks to everyone else who provided guidance. I love this discussion board.
                          Chris
                          Chris Enstrom
                          2011 Z06, red/red
                          • David D.
                            • January 1, 2005
                            • 416
                            If I may ask....
                            How difficult of a job is this, to rebuild/refurbish the leaf spring(s)?
                            How does one know if any of the leafs are bad and need to be replaced?
                            If there is an article / pdf on how to.....could someone please post here or send to me. I have a '64 with 9 leaf.
                            I wish mine looked as good and clean as shown in the photos......
                            Thanks in Advance,
                            David
                            • Stephen L.
                              • May 31, 1984
                              • 3157
                              David,
                              Rebuilding the spring is easy. Removing/replacing is easy... just remember there are forces involved that must be relieved to avoid injury. 4 bolts hold the center section and a bolt at each end and the spring is out. You'll have some forces present at the ends so support the end with a jack as you loosen the bolts.
                              When reinstalling, do not tighten the center 4 bolts until the car weight is back on the wheels. Otherwise you may break the ears off the diff case trying to torque these bolts.
                              If there is little or no corrosion on the leaves then a good cleaning and repaint is all that is needed.
                              I was able to reuse most of my 40 yr old liners, purchasing just 2 long new ones and then cutting the used ones shorter to remove the worn ends, and moving them up the spring.
