Engine code on 1960 - VI2I5XXB - NCRS Discussion Boards
  • Frank C.
    • January 27, 2009
    • 4
    VI2I5XXB is the engine code on the stamp pad of a 60 that I'm looking at. There is no serial number derivative on the stamp pad. The engine has two four barrel carbs.
    Anyone know anything about that code?
    Thanks. Frank
  • Cecil L.
    • May 31, 1980
    • 450
    Re: Engine code on 1960 - VI2I5XXB
    First of all since it's a V for the Flint engine plant instead of an F, that would indicate a 67 or later casting assembled on the 15th of December. You need the casting date to tell which year. I don't have any 3 letter "X" suffix codes in my references, but the XX or XB should be a 69 350 with manual trans in a truck.
    • William C.
      • May 31, 1975
      • 6037
      What is the block casting number, that will give a fair idea of what size engine it is.
      Bill Clupper #618
      • Frank C.
        • January 27, 2009
        • 4
        Bill, the block casting number is 3892657. This engine has a draft tube which should indicate earlier rather than later.
        Thanks. Frank
        • William C.
          • May 31, 1975
          • 6037
          67 302/327 block, nice piece if the date is good for a 67 Z-28.
          Bill Clupper #618
          • Mike M.
            • May 31, 1974
            • 8408
            Thanks. Frank
            road draft tubes(ie, block drilled for crankcase vent tube or later venting systems) was used in the small journal crank sbcs from 56 thru 67(and maybe 68 but c-3's not my forte).once the large journal cranks came along, the block wasn't drilled for the venting mechanism.mike
            • Frank C.
              • January 27, 2009
              • 4
              So what do you think, a nice replacement engine for this 1960 4 speed?
              Thanks for your help.
              Frank
              • William C.
                • May 31, 1975
                • 6037
                Nice replacement, but depending on the date, might be worth enough to a Z-28 guy to pay for a matching numbers 283.
                Bill Clupper #618
                • Frank C.
                  • January 27, 2009
                  • 4
                  I'm looking everywhere for the XXB suffix and can't find it. I may have not mentioned that the engine didn't have a serial number derivative on the stamp pad. Is this possibly an engine purchaced from a dealer?
                  • William C.
                    • May 31, 1975
                    • 6037
                    couple of things, look for the S/N on the drivers side vertical flange of the block, where the engine meets the bellhousing right above the oil filter, not unusual for a pass car to be stamped there, right over the grain of the casting. Otherwise might be a over the counter piece. The date may be a clue. Is the engine ID code really XXB? if not what are the two characters before the "B"
                    Bill Clupper #618
                    • Edward M.
                      • November 1, 1985
                      • 1922
                      I have seen this engine code before, and I have racked my feeble brain trying to recall where. It stuck in my mind because of the two Xs (I was thinking triple X, so you know where my mind was).
                      I have looked through most of my engine references, but haven't found it yet.
                      It seems like "service replacement engine" comes to mind, but that is just a vague memory.
                      I'll keep looking.
                      • Cecil L.
                        • May 31, 1980
                        • 450
                        Maybe you're thinking of XXG which I've seen on a lot of 65 409 crate engines.
