63 Alternator mounting bracket shimming issue - NCRS Discussion Boards
+ More Options
Posts
  • Steve D.
    • February 1, 2002
    • 990
    To install AC, I have moved the alternator to the driver side. The original bracket is like every bracket I have ever seen, and has a split pin shim that is driven in the rear hole of the bracket. The pin is tapped in to keep the alternator from wobbling on the bolt. The bracket that I purchased (Corvette Central) for the driver side did not come with such a pin, and the construction of the rear "ear" of the bracket is such that there is not enough metal to allow drilling out the hole to accept the pin. I have tried to use washers as shims, but can't get a precise enough shim to eliminate the wobble. Two questions: 1) Does anyone know where I can get a driver side bracket equipped with the pin, or failing that 2) any suggestions on shimming the one I have?
    Steve
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11367
    Re: 63 Alternator mounting bracket shimming issue
    Steve, I noticed in the AIM that the bracket for the drivers side mount also shows a "bushing" at the rear hole. It sounds like the one that CC supplies isn't the correct part. Did you talk to them about it?
    Rich
    • Steve D.
      • February 1, 2002
      • 990
      Rich,
      I talked to their product assistence person yesterday; he was going to check and call me back.
      Steve
