Is there an easy (???) way to remove the speedometer cable at the transmission on my 64 4 speed? The previsous owner apparently had the wrong cable so I thought I would replace it with the correct one, only to find out that between the shift linkage and the transmisson mount brackets I can't get my fingers on the lock nut with enough pressure to twist it off. Am I missing something obvious?
