The engine that we just removed from my 1964 A/C coupe turns out to be a correct numbers matching 1971 base 270HP 350 (code CJK). I need a correct Corvette (rear center of sump drian plug location?) oil pan for the #870 327 that I'm building. Is the pan from the '71 350 the same as the original '64 327 pan? All I need is a 4 quart pan as I am trying to piece together a correct L35 300HP 327. The '71 350 should be worth more as a complete assembly so perhaps I should be looking for a 327 oil pan. Also should be looking for someone who needs a '71 engine. The casting code on my 350 is Feb 7, 1971. Thanks for the help!
Oil pan changes from 1964 to 1971?
Re: Oil pan changes from 1964 to 1971?
Keen Parts has a new reproduction oil pan that should judge as original. There was a long thread several months ago on the pan
http://keenparts.com/Dick Whittington- Top
Peter-----The engine that we just removed from my 1964 A/C coupe turns out to be a correct numbers matching 1971 base 270HP 350 (code CJK). I need a correct Corvette (rear center of sump drian plug location?) oil pan for the #870 327 that I'm building. Is the pan from the '71 350 the same as the original '64 327 pan? All I need is a 4 quart pan as I am trying to piece together a correct L35 300HP 327. The '71 350 should be worth more as a complete assembly so perhaps I should be looking for a 327 oil pan. Also should be looking for someone who needs a '71 engine. The casting code on my 350 is Feb 7, 1971. Thanks for the help!
All "4 quart" small block Corvette oil pans from 1963 to 1974 were exactly the same. The only possible exception is some late 1974's which may have used the 75-79 style pan.In Appreciation of John Hinckley- Top
