62 heat riser - NCRS Discussion Boards
62 heat riser
  • John F.
    • March 23, 2008
    • 2419
    62 heat riser
    Does anyone have a good close-up picture of one out of the car? Looking at it from under the car, it appears the little spring on the outside is loose. This is for a 250hp-327..John
  • Dennis C.
    • June 30, 2002
    • 888
    Re: 62 heat riser
    John,
    Here are some pictures of the heat riser for my '61, 283. I will let others determine if it is the correct one.
    The weight is stamped GM and the number, which I believe is the casting number, 6844.
    I haven't put the valve back in yet after replacing both springs. The springs in the photo are not original to this heat riser.
    Dennis
    • John F.
      • March 23, 2008
      • 2419
      Re: 62 heat riser
      Thanks Dennis. Very helpful....John
