Horn relay - NCRS Discussion Boards
Horn relay
  • Donald P.
    • June 30, 2006
    • 7
    Horn relay
    I need a correct horn relay on my '67 vette for NCRS judging purposes. I contacted Corvette Central for a new relay. The relay that they say is correct in their catalog has a black plastic boot; however, my 1967 NCRS TECHNICAL INFORMATION MANUAL and JUDGING GUIDE FOURTH EDITION says the translucent, semi-clear boot is correct and that the black boot is incorrect. Has the manual been updated accepting the black boot as correct or is Corvette Central wrong?
    Don
  • Ralph P.
    • February 1, 1990
    • 253
    Re: Horn relay
    The "837's" are available on Ebay ...they were used on other GM's of that era . You'll have to be careful of the usual beadblasted cases & "yellowed" plastic . Keep looking for a good one...
    • Wayne M.
      • March 1, 1980
      • 6414
      Re: Horn relay
      Originally posted by Donald Pickles (45994)
      .... my 1967 NCRS TECHNICAL INFORMATION MANUAL and JUDGING GUIDE FOURTH EDITION says the translucent, semi-clear boot is correct and that the black boot is incorrect. Has the manual been updated accepting the black boot as correct or is Corvette Central wrong? Don
      Don -- here's a junkyard "837". AFAIK, they're all translucent.
      • Mike M.
        • May 31, 1974
        • 8408
        Re: Horn relay
        Don
        go junkyarding. they are very common in GM cars of the 60's.mike
          Re: Horn relay
          Don
          Corvette Central is wrong - they're selling a later Service "functional replacement", not the 837 relay configured as used in 1967 production. The CC relay will function just fine, but will get appropriate deductions in judging based on how it deviates from the original 837 in terms of finish, date, installation, configuration, and completeness.
            Re: Horn relay
            Yep, and one of the reasons for the change ('66-67 + the one year only '68 horn relay) is the translucent/clear plastic turned yellow, got brittle and broke from exposure to UV and heat. That's why good used originals tend to be though to find and trade up in $$$...
            • Donald P.
              • June 30, 2006
              • 7
              Re: Horn relay
              Thank you!
                Re: Horn relay
                No problem and count your LUCK because you have TWO years of fellow donor cars to provide used originals while the guys with '68 cars are locked into their one year only profile...
                • Ralph P.
                  • February 1, 1990
                  • 253
                  Re: Horn relay
                  Don, you can see an example on Ebay Motors @ item # 130304697921... a decent looking one at that....
                  • Dick W.
                    • 10483
                    Re: Horn relay
                    John Pirkle usually has a few restored and ready to install. 706.860.9047
                    Dick Whittington
                    • Jeff A.
                      • January 1, 2000
                      • 312
                      Re: Horn relay
                      The front plastic is broken off on that one
                      try this one ---> Item number: 110384028339
                      My Cars
                      • Donald P.
                        • June 30, 2006
                        • 7
                        Re: Horn relay
                        Thank you, but John is out of the horn relays at this time.
                        • Donald P.
                          • June 30, 2006
                          • 7
                          Re: Horn relay
                          Thank you, Ralph, but since this new to me do you think it is worth $100?
                          • Larry M.
                            • January 1, 1992
                            • 2701
                            Re: Horn relay
                            Don:
                            Paragon Reproductions also has rebuilt originals listed in their C2 catalog. No price given, only "call". Probably won't be cheap.
                            Otherwise check Hemmings, E-bay, swap meets or a visit(s) to local junkyards.
                            Larry
                              Re: Horn relay
                              Beauty lies in the eyes of the beholder... The $100 price isn't out of line with the general market for either NOS or refurbished, pristine, original horn relays from the '66-67 or '68-69E era. The integrity of that translucent plastic insulator is what generates relative market volume!
